Eurosens Dominator fuel level sensor will have the lowest cost during the lifecycle of GPS tracking system than any other sensor.
Especially if you take into account not only the cash costs, but also the working time of the personnel (diagnostics, repair, replacement, calibration of the tank, etc.). .
You can read about this more there:
I am owner of fleet. Why I should choose Eurosens Dominator?
Here we will repeat once again that we want to cut all possible cases of departure to check the sensor operation. It is very expensive job when sensor is installed 200+ kilometers away from your office. With Eurosens Dominator the most of problems can be diagnosed and solved remotely, thanks to modular design of sensors. This saves a lot of time and money (both yours and the customer).
While your rivals are going to offer cheapest possible GPS trackers and sensors with low reliability you can go to customer from the other side. And offer more prestigious and more economic product at the same time. It is easy to demonstrate to customer!
Difference in price between the cheapest fuel level sensor and Eurosens DOminator is less than cost on the one trip of your technicians to replace a burned sensor!
