Yes, you just need to choose the model of the flowmeter with the desired interface. The most universal solution is to connect the Eurosens Direct / Delta CAN flowmeter to a GPS tracker via a CAN interface. If your tracker has a CAN interface, then you can connect our flowmeter with a CAN interface.
The CAN interface is digital, you get not only fuel consumption, but also a lot of other data: fuel consumption in supply and return lines, fuel temperature, time of intervention in the flowmeter operation, etc.
Some monitoring terminals support the connection of the fuel flowmeter via the digital RS485 interface using the Eurosens Delta (Galileo) protocol or MODBUS protocol.
The simplest but also the least functional is the connection of the fuel flowmeter via a pulse interface, and information is transmitted about only fuel consumption. The calculation of instant fuel consumption should be carried out by the dispatcher software.
