Production facilities of Mechatronics are located in Vileika. This small Belarusian city has been known since the times of the USSR as an engineering center. Our team is the main capital of our enterprise. Nowadays you can think that everything is produced in China, and then under the invented brand goes to the local market. It’s not our way, in Vileyka we invent, develop and make a full production cycle – as this ensures product control at all stages of the process.
Electronics hardware design and development services Our team offers engineering services of hardware and firmware/software development transforming your project  to a turn-key solution, including:
  • smart sensors and actuators, dataloggers and modern data transfer interfaces (MODBUS, CAN, Wi-Fi, Bluetooth, GSM, NB IoT, LoRa, etc.) ;
  • design of molds, PCB and PCBA;
  • Database web services ;
  • Mobile Apps (smartphones, tablets) and messengers (Telegram, Whatsapp bots).
Our factory is placed in Vileyka town in Belarus and equipped with CNC machines, 3D-printers and testing equipment. For CAD/PCB design we use modern engineering software. Our products have won some national awards. Payment after testing!
Our Portfolio
Fuel consumption meters.
Features : high precision cnc processing, magnetic field measurement, STM32, CAN and MODBUS interfaces, service software, mould design. Fuel level sensors
Eurosens Dominator CAN
Fuel level sensor Eurosens Dominator
Features : modular design, capacitive method of measurement,  STM32, CAN and MODBUS interfaces, service software, mould design. Axle load sensors
DPS CAN
Features : Thin film sensor bridge,  STM32, CAN interfaces, service software Temperature sensor
DTS RF-T wireless temperature sensor for refrigerator truck
Features : STM32, 433 RF band, battery-powered, ultra-low power consumption. National fuel consumption meter calibration stand
Features :  PLC Mitsubishi, MODBUS, pump and valves control, various meters integration, software control Portative fuel consumption meter calibration stand
Features :  MODBUS, STM32,  pump and valves control, software control Cloud CAN-bus messages decoding service www.can2sky.com Features :  SAE J1939, Laravel, MySql, PHP. And many other projects
Metal processing facilities:
Operation Size, mm Precision Material to be processed Comment
Automatic machining Details of round and hexagonal rolled products up to 20mm in diameter and up to 50mm in length Tolerance grade: 11 Aluminum and brass alloys For mass and large-scale production
CNC cutting Blanks with a diameter of 250 mm and a length of up to 500 mm Tolerance grade: 9 Alloys, steel and non-metallic materials Low volume production is possible
CNC milling Details till 5 kg mass and max dimensions 300×250×100 Tolerance grade: 9 Alloys, steel and non-metallic materials Low volume production is possible
Coordinate-boring and drilling work Drilling diameter from 0.5 to 150 mm in details with max dimensions 300×250×100 Tolerance grade: 7, positioning +0.02 mm Low volume production is possible
Forging production (Bending, cutting, stamping) Sheet metal processing (thickness up to 3 mm) For mass and large-scale production
Casting of aluminum alloys Details with mass up to 0.5 kg For mass and large-scale production
Casting of plastics Details with mass up to 0.3 kg For mass and large-scale production
Application of galvanic and paint coatings Zinc plating, anodizing, oxidation for ferrous and non-ferrous metals For mass and large-scale production
