Accurate fuel level sensor compatible with almost any GPS tracker or SCADA system
The Dominator series fuel level sensors are designed to minimize the operating costs of a fuel consumption monitoring system over its entire service life.
Advantages of eurosens Dominator : (for GPS tracking provider).
  • Modular design allows to quickly create a sensor of the right length from the stock.
  • Convenient sensor sealing against sensor extraction and cable disconnection.
  • Modular design simplifies diagnostics and technical support.
  • Universal protocols LLS/MODBUS/CAN J1939.
  • The modular design simplifies diagnostics and technical support.
Advantages of fuel level sensors Dominator (for fleet owner):
  • No need to unscrew the self-tapping screws fixing the mounting plate to the tank when removing the sensor for verification of the measuring instrument.
  • The modular electrode design allows the sensor to be extended with a new electrode. When reinstalling old sensors to new equipment, it is enough to buy an electrode for extension, but not a new sensor.
  • Replacement of the electronic module of the sensor does not require recalibration of the tank (we use previously calibrated electrodes).
  • Dominator electrodes can be flushed from contamination without opening the case and violating the warranty. This does not require the involvement of the monitoring service provider (paid on-site visit).
Thus, it becomes possible to minimize the number of visits of the monitoring service provider for maintenance of fuel level sensors and, as a consequence, the cost of operation of the vehicle monitoring system.
Power voltage, V
10 – 50
(9-32 for Dominator RS 485)
Max measurement error, from sensor length ±1%
Temperature range,°C -40 – +85
Output interfaces Analog voltage(0-15 V), frequency (from 200 to 2000 Hz), RS-232, RS-485, CAN 2.0B, K-line
Service interface RS-485 or ISO 9141 (K-Line)
Protection class IP 67
Operation manual
Eurosens Dominator configurator
Eurosens Dominator specifications
Eurosens Dominator Mini specifications
Eurosens Dominator RS flyer
Eurosens Dominator RS 485 flyer
Advantages of the Eurosens Dominator fuel level sensors
Certificates
Sertificate of  Custom Union Technical Regulations 012/2011 (explosion-proof)
Eurosens Dominator certificate (E-mark)
eurosens Dominator version Mini (slim enclosure)
eurosens Dominator in standard version – connector is mounted directly on sensor enclosure
Eurosens Dominator CAN
Fuel level sensor Eurosens Dominator Fuel level sensor Eurosens Dominator
Easy installation and sealing
eurosens Dominator modifications are described below
Х
Y
Output interface
Interface description
 version index
Description
RS 485
RS485
Ex
explosion-proof
AF
analog output, power supply 0.5-15 V (customizable, limited by power supply)
frequency output, 200-2000 Hz (customizable)
K-line single-wire interface
RS
RS-485, RS-232
Ext
special version (custom length)
CAN
CAN 2.0 interface
AFRS
RS232, RS485
Mini – version with lower height of sensor enclosure.
We don’t use the “Mini” index with RS 485 and Bt modifications because they exist only in Mini version.
RSCAN RS485
CAN
Bt
built-in battery and wireless interface Bluetooth Low Energy
Sensors can be supplied as Eurosens Dominator sets
For developers : Eurosens Dominator 3D CAD drawings
Eurosens Dominator IGS file
Eurosens Dominator STEP file
Use with:
Eurosens Destination 01_200x200
Dominator Electrode 1&2_200x200
Dominator Electrode
Eurosens Cable
Eurosens Cable
