Ultrasonic liquid level sensor Dizzi
Ultrasonic level sensor Eurosens Dizzi is used for non-contact (non-invasive) level measurement of acoustically transparent liquids. Measurement is done by external echolocation through the bottom of the tank.
- No tank modification required. All sensor components are placed outside the tank. It is very important when you measure aggressive, explosive, liquid foodstuff, as well as highpressurized liquids.
- You can measure the level of any liquid, including liquefied gas.
- Smart self-diagnostic algorithm provides stable data.
- Explosion-proof certified ( 0Ех ia IIC T6 Ga, [Ex ia Ga] IIC )
Power voltage, V | 9 – 30 |
Max. thickness of the tank wall, mm | 0 – 5 |
Resolution, in static condition, mm | 0,1 |
Reverse polarity protection | Yes |
Temperature range,°C | -40 – +85 |
Output interfaces | RS-485 |
Digital protocols | LLS, Modbus |
Seal rating | IP 67 |
Eurosens Dizzi Flyer |
