Convenient and reliable sealing of fuel level sensors for their installation and maintenance. How is this done? The sensor housing, connectors and bayonet plate have special holes for sealing. You can choose the most convenient method: Option 1.
The sealing cable is threaded into the installed sensor from above into special through holes in the sensor housing, which coincide with the holes in the bayonet. Then the cable is removed from the bayonet and a seal is installed.
The electrical cable and sensor are sealed with two seals.
Option 2. The same, but the sensor and the electrical cable can be sealed with one seal.
Variants 1 and 2 can be used both for the initial installation of the sensor and for modular replacement. Option 3. The sealing cable is threaded through the bayonet from below until it is fastened to the tank. When installing the sensor, the cable is threaded through the through holes from the bottom up. The seal is installed at the top.
This type of sealing can only be used for initial installation.
We are in social media
Youtube
