can be done inside Eurosens Dominator fuel sensor Smart STM32-based electronic module of Eurosens Dominator fuel level sensor now can detect fuel fheft event and change the state of alarm discrete output. You can use this signal as an alarm input of your GPS tracker or connect relay. Major advantage is faster response compared with GPS tracking platform fuel theft detection. Driver can be informed by SMS about fuel theft and it will be not too late. Usual Dominator RS/Dominator CAN can be used. K-line/OUT wire – alarm output. Depending from connection you can switch built-on Pull-up resistor ON/OFF. Fuel theft threshold (max. fuel consumption in liters per hour) must be set in confugiration software. And tank calibration table must be stored inside sensor.
