With this form you can create the calibration table of the horizontal cylinder tank. You must first cut the sensor to the required height and measure the value of the sensor detector in the “full” and “empty” states using the Eurosens configurator. To do this, cut the sensor can be turned over and fill the fuel between the electrodes, completely filling the gap. Record the obtained detector value as “Full” sensor detector frequency. Then drain the fuel and measure the detector value corresponding to the empty tank. The resulting numbers should be recorded in this form.
Right click to “Save as”
