Cutting of electrodes at installation. Designations on the scheme: 1 – fuel tank 2 – fuel h2 – possible dirt or water L – initial length L1 – the recommended cutting length When installing the bottom stop, the distance from the bottom end of the electrodes to the bottom of the tank should be approximately 30 mm. In the absence of a bottom stop: 10-15mm. When the bottom stop is installed, the sensor should protrude beyond the upper plane of the tank by about 15 mm after immersion in the tank . In the absence of the bottom stop, the sensor should be completely lowered onto the bayonet plate without touching the bottom of the tank.
- Digitalization of waste management: Insights from German private and public waste management firms
(more…)
- New amendment of the Annex X to Regulation (EU) 2018/858 on standards for accessing vehicle on-board, repair and maintenance information through the OBD2 interface is coming
- Android Auto and Apple CarPlay touch screens impair reaction times behind the wheel more than alcohol and cannabis use.
- How to Decode Vehicle's CAN Bus Data
- Machine Learning-Based Driving Style Identification of Truck Drivers in Open-Pit Mines
- Products
- Fuel consumption meters
- Fuel level monitoring
- Accessories for Eurosens Dominator
- Eurosens Dominator
- Composite fuel level sensors/Dominator Electrode
- Dominator mounting set
- Eurosens Dominator BT
- Bayonet mount
- Eurosens Dock converter
- Eurosens Dash fuel gauge adapter
- Eurosens LPS
- Universal liquid level sensor Eurosens MWS
- Eurosens Dizzi
- Eurosens Tank Manager Android App
- Eurosens Difference onboard weighing system
- Information Displays
- Interfaces and connection modules
- Eurosens Datalink RF bridge
- Eurosens Defender 24
- Service tool Eurosens Destination 02 (K-line,RS232,RS485 / USB)
- Service tool Eurosens Destination CAN (K-line,RS232,RS485,CAN / USB)
- Service tool Eurosens Destination 02 Lite (K-line / USB)
- Eurosens Difference-T4
- Eurosens Modem
- Eurosens BT-COM Mini – Bluetooth to RS485 bridge
- Eurosens BT-COM Bluetooth to RS485 bridge
- Sensors
- Tire pressure monitoring systems
- Software
