Wireless tilt angle sensor Eurosens Degree BT has different operation modes. Lets see how it is connected to the popular GPS trackers Teltonika FMB XXX in the modes : tilt angle monitoring and events detection, concrete mixer truck monitoring, boom monitoring. Teltonika GPS trackers should have Bluetooth Advanced settings (section Bluetooth 4.0 – Advanced ) If we want to use Eurosens Degree BT in simple tilt angle/event detection mode we can use these settings:
To save your time you can download attached xml-file and copy it to your My Documents/Presets folder of Teltonika configurator.
Eurosens Degree Bt preset
After this procedure Eurosens Degree BT sensor appears in presets:
Save settings and you can check how GPS tracker reads BLE data in the Status section of teltonika configurator
Our data is:
- BLE sensor 1: BLE Custom 2 – Angle X
- BLE sensor 1: BLE Custom 3 – Angle Y
- BLE sensor 1: BLE Custom 4 – Angle Z
- BLE sensor 1: BLE Custom 5 – Sensor status (refer to the Eurosens Degree BT BLE protocol document)
- BLE sensor 1: Fuel level – Number of events
- BLE sensor 1: Fuel frequency – Number of complex events
- BLE sensor 1: temperature – temperature
According to the Teltonika AVL ID wiki our data will have these IDs in the Teltonika protocol: //wiki.teltonika-gps.com/view/FMB_AVL_ID
BLE sensor 1: BLE Custom 2 – Angle X ID=463
BLE sensor 1: BLE Custom 3 – Angle Y ID=464
BLE sensor 1: BLE Custom 4 – Angle Z ID=465
BLE sensor 1: BLE Custom 5 – Sensor status (refer to the Eurosens Degree BT BLE protocol document) ID=466
BLE sensor 1: Fuel level – Number of events ID=270
BLE sensor 1: Fuel frequency – Number of complex events ID=306
BLE sensor 1: temperature – temperature ID=25
To use Eurosens Degree BT as a concrete mixer drum rotation sensor you can use same preset:
When sensor in the Drum rotation mode we will get another dataset:
BLE sensor 1: BLE Custom 2 – Drum operation speed (rpm) ID=463
BLE sensor 1: Fuel level – Drum operation time (minutes) ID=270
BLE sensor 1: Fuel frequency – Number of drum starts ID=306
For excavator (boom control) we can use same preset with angle monitoring mode:
With same preset when sensor is in boom control mode :
BLE sensor 1: Fuel level – Current status of operation (1 – in operation, 0 – not in operation) ID=270
BLE sensor 1: Fuel frequency – Total operation time (minutes) ID=306
