This Wialon Application allows you to determine the weight of garbage transported by a garbage truck
We have already created a software module for the monitoring system Wialon, which forms a trip report of a dump truck with cargo. More information – there. The logic of the dump truck operation implies cycles of loading and unloading, which were calculated by the application. The logic of the garbage truck is different: instead of a single load, we have many small loads, which, cannot be determined automatically based on data (due to the small size of the load). Instead, we can determine the place of unloading of the garbage truck, compare it with the list of specified geo-zones (polygons) and determine the unloaded cargo weight.
It was realized in the new Wialon Application, specially for waste trucks.
Example of report:
Thus, it is not necessary to calculate the value of the weight of the load manually on the basis of data plot- this is done by the Wialon application. This application allows you to achieve acceptable accuracy even for objects with leaf spring suspension.
