Most diesel engines have 2 fuel lines – supply and return. The fuel enters the engine through the supply line, the excess fuel returns to the tank via the return line. To determine the fuel consumption of the engine is necessary to calculate the difference between them. So the two-channel (differential) flowmeter Eurosens Delta works. In cases where there is no return line, you can use a single – channel Eurosens Direct flowmeter.
