Eurosens Dash device should be connected to power, ground, ignition voltage signal and RS-485 interface (which connects GPS-tracker and installed fuel level sensor). It is placed near GPS tracker under the dashboard and doesn’t have a long cable. Eurosens Dash works in listen-only mode and reads fuel level data during GPS-fuel level sensor interaction. Eurosens Dash output – emulation of resistive level sensor output and alarm lamp control output which should be connected to the gauge or dashboard instead of same vehicle sensor wires.
To set up Eurosens Dash for different gauges and dashboards – special configuration software is used. For settings RS485 interface is used and you will need USB-rs485 adapter, for example, Eurosens Destination 02.
