Eurosens Dash emulates resistive signal of a vehicle fuel level sensor. It is used when we want to install accurate fuel level sensor of capacitive type (like Eurosens Dominator) instead of vehicle sensor and avoid drilling a new hole.
When we cannot use Eurosens Dash:
1. Vehicle sensor does not have an resistive output but uses another interface (frequency) or contains built-in electronic module.
2. Vehicle sensor is assembled together with fuel sender pipes. Obviously, we cannot remove it.
Resistive fuel sensors have different output ranges and Eurosens Dock can be tuned for operation with different gauges and dashboards.
Also Eurosens Dash provides a switch signal for alarm fuel lamp control.
