Eurosens fuel consumption meters are a popular solution for measuring the actual fuel consumption of the main and auxiliary engines of river and sea vessels, as well as powerful mining trucks.
For installation on powerful engines (power over 1000 kW), a differential scheme is used, with two Eurosens Direct meters of the 1500, 3000 or 5000 series.
Typical setup includes two fuel consumption meters, Eurosens cables and the Eurosens on-board display, which calculates the consumption of the engine and transmits the results to the required interface (RS485 or CAN / NMEA2000). In this case, data exchange between the display and flow meters is carried out via the internal bus K-Line.
Eurosens cables and special T-connectors allow reliable installation.
