Wialon Application which is used for cargo weight trips reporting. Onboard cargo weight measurement is a complex technical task. Eurosens Difference onboard weighing system will help you to measure real cargo weight in the truck or trailer compartment. Example of cargo weight data for dump truck with leaf spring suspension (worst case, for air suspension weight data much better).
Green plot – cargo weight, rest plots are axle load and speed. Due to leaf spring nature we can’t use these data directly but smart data processing we can receive good results. Wialon trip reports use only one point of sensor data at the beginning/end of the trip. We need to average data cargo weight during all trip.
So, based on this idea we create this app which perform these functions:
1. Read all sensors data from Wialon for desired period of time.
2. Load/Unload events recognition , detect start and end of the cargo trip.
3. Calculate average cargo weight value (and some other smart processing too).
4. Create the web report and excel report. Web report is interactive, places of load/unload events are clickable and shows the event position on the map. Screen of Wialon App with results is attached.
Our Wialon App report contains : place and time of Load/Unload events, cargo weight and distance of cargo trip.
