This table will help you to choose an equivalent flow meter model amoung three different manufacturers : Mechatronics, Technoton and Aquametro. You can save some money with it! Note that Aquametro does not produce fuel consumption meters with modern digital interface (RS232/RS485/MODBUS/CAN bus). When building new monitoring system from scratch we recommend you to look into fuel meters with digital interfaces, because then provide much more data. You can read about advantages there. Any Eurosens fuel meter can have RS485/CAN bus interface. So, if you are looking for an alternative of VZO15 FL 130/25 RV and result is Direct PN A500I FL – try to use Eurosens analog with RS or CAN interface (Direct RS500I or Direct CAN500I).
Sometimes fuel consumption meters are used with onboard displays. Our Eurosens Display RS can replace much more expensive displays from Aquametro : DFM-BC, Flow Computer F113, Flow Computer F113 (RS232/RS485/Modbus), Differential Flow Computer F116, Flow Computer F113 (RS232/RS485/Modbus) can be replaced. Eurosens Display CAN also can provide you with fuel consumption data by CAN bus interface.
Type of fuel consumption meter / Brand
Aquametro
DFM
Eurosens
Meter with display
VZO4
DFM 100B
DFM100C
Direct A100I
Meter with display
VZO8
DFM250B
DFM250C
Direct A250I
Meter with pulse output interface
VZO 4 OEM, VZP4
DFM100AK
Direct PN100
VZO 8 OEM, VZP8, DFM8S
DFM250AK
Direct PN250
Meter with display and pulse output interface
VZO4RE, VZD4
DFM100CK
Direct PN100I
VZO8RE, VZD8
DFM250CK
Direct PN250I
Differential meter with pulse output interface
DFM8ECO, DFM8D
DFM250D
Delta PN250
DFM12ECO
DFM500D
Delta PN500
DFM 20S
DFM Marine 1000CK TA
Direct PN1500
DFM25S
DFM Marine 2000CK TA
Direct PN1500
Meter with display
VZO15 RC 130/16
DFM500CK
Direct A500I
VZO15 RC 130/16 RV, VZF15 RC 130/16
DFM500CK
Direct PN A500I
Meter with display
VZO15 FL 130/25
DFM Marine 1000C FA
Direct A500I FL
VZO15 FL 130/25 RV, VZF15 FL 130/25
Direct PN A500I FL
Meter with display
VZO20 RC 130/16
DFM Marine 1000C TA
Direct PN1500
VZO20 RC 130/16 RV, VZF20 RC 130/16
Direct PN A1500I
Meter with display
VZO20 FL 130/25
DFM Marine 1000C FA
Direct A1500I FL
VZO20 FL 130/25 RV, VZF20 FL 130/25
Direct PN A1500I FL
Meter with display
VZO25 RC 130/16
DFM Marine 2000C TA
Direct PN1500
VZO25 RC 130/16 RV, VZF25 RC 130/16
Direct PN A1500I
Meter with display
VZO25 FL 130/25
DFM Marine 2000C FA
Direct A1500I FL
VZO25 FL 130/25 RV, VZF25 FL 130/25
Direct PN A1500I FL
Meter with digital interface (RS232)
none
DFM100A232, DFM250A232, DFM500A232
Direct RS100, Direct RS250, Direct RS500
Meter with digital interface (RS485)
нет
DFM100A485, DFM250A485, DFM500A485
Meter with digital interface (CAN)
none
DFM100ACAN, DFM250ACAN, DFM500ACAN
Direct CAN100, Direct CAN250, Direct CAN500
Meter with display and digital interface (RS232)
none
DFM100С232, DFM250С232, DFM500С232
Direct RS100I, Direct RS250I, Direct RS500I
Meter with display and digital interface (RS485)
none
DFM100С485, DFM250С485, DFM500С485
Meter with display and digital interface (CAN)
none
DFM100СCAN, DFM250СCAN, DFM500СCAN
Direct CAN100I, Direct CAN250I, Direct CAN500I
Differential meter with digital interface (RS485)
none
DFM100AD485, DFM250AD485, DFM500AD485
Delta RS100,      Delta RS250,      Delta RS500
Differential meter with display and digital interface (RS485) none DFM100CD485, DFM250CD485, DFM500CD485 Delta RS100I,      Delta RS250I,      Delta RS500I
Differential meter with digital interface (CAN) none DFM100ADCAN, DFM250ADCAN, DFM500ADCAN Delta CAN100,  Delta CAN250,  Delta CAN500
Differential meter with display and digital interface (CAN) none DFM100CDCAN, DFM250CDCAN, DFM500CDCAN Delta CAN100I, Delta CAN250I, Delta CAN500I
