The order is described in the installation manual, which you can download from our website //mechatronics.by/products/load-control/ Also you may look at our youtube channel
//www.youtube.com/watch?v=sjEvSfyjLfY
Features: Installation of sensors Eurosens Difference 01 (air spring suspension) requires tie-in pneumatic lines. Use the mounting kit from the manufacturer, but it is necessary to pre-specify the diameter of the hoses of the vehicle pneumatic lines. Installing sensors Eurosens Difference 02 (leaf spring suspension) often involves welding to fix the sensor to the chassis of the vehicle. To calibrate the Eurosens Difference system (either sensors only), bed scales (Fig. 1) or stationary platform scales (Fig. 2) are required. To calibrate a road train with a semitrailer, at least 3 axial loads are required (along all axes selected in accordance with the design scheme): • axle loads of the tractor, uncoupled trailer; • axle loads of tractor and trailer (empty); • axle loads of tractor and trailer (full). To calibrate a truck or trailer, 2 axle loads for all axles selected in accordance with the design scheme are sufficient for a full and empty state. Please note that full condition means the need to fully load the car with maximum weight.
Remote calibration is possible using the GPS tracker with remote access feature (Smart from Navtelecom). Remote calibration greatly simplifies the installation procedure. More information – in video.
